1440P Monitor Questions
Doixk
Hello all, I recently upgraded my GPU to a 4070 Super and thought it was time to upgrade to a 1440p display. I am currently using (2) 27" 1080P displays and my main one that I use for games is an Asus VG27QM1A 280hz model. I am uncertain about either upgrading my main display to a 1440p 27" or whether to triple monitor my setup and get a 34" ultrawide 1440p display along with my 2 27" ones. I will list all the displays I am considering below for both 27" and 34" and any info or different displays recommended would be extremely helpful in deciding since I am new into the 1440p space. Also to add, I am not too picky on price depending on the value that I would be getting. (I wouldn't want to spend $1000 on a display that isn't worth it.)
27":
Asus VG27AQM1A
Samsung Odyssey G65B 27"
Alienware AW2723DF
Alienware AW2724DM
Gigabyte M27Q
Asus XG27AQMR
34"
Samsung Odyssey G5 34"
Gigabyte G34WQC
Dell S3422DWG
LG 34GP83A-B
OLED Entries:
Alienware AW3423DWF
MSI MEG 342C
Current Build;
CPU: Ryzen 7 5800X3D
GPU: Gigabyte Aero OC 4070 Super
Case: Corsair 6500x
Ram: 32 GB GSkill Trident Z Neo 3600
Motherboard: Asus ROG Strix B550-A
AIO: Corsair H150i Elite Capellix
PSU: Corsair RM1000e
SSD: Samsung 980 Pro 2TB
HDD: Seagate Firecuda 8TB
27":
Asus VG27AQM1A
Alienware AW2723DF
Alienware AW2724DM
Gigabyte M27Q
Asus XG27AQMR
34"
Gigabyte G34WQC
Dell S3422DWG
LG 34GP83A-B
OLED Entries:
Alienware AW3423DWF
MSI MEG 342C
I'd steer clear of crazy multimonitor setups, they're just unnecessary unless you have a specific need for it. One monitor is more than capable, a second monitor being marginally useful.
I spent years using crazy multimonitor setups until about 4 years ago where I went back to one quality monitor. If you get a 34" ultrawide, its more than sufficient as a single display in my opinion, worst case, having another monitor off to the side so you can waste energy displaying something you're not looking at often anyways.
Ryzen 7950x3D PBO +200MHz / -15mV curve CPPC in 'prefer cache'
RTX 4090 @133%/+230/+1000
Builder/Enthusiast/Overclocker since 2012  //  Professional since 2017
It is definitely possible for me to just keep one ultrawide as a primary display. Although I have had 2 monitors now for almost 5 years and the second one has been more than useful many times. Whether it's just having discord up, diagnostics while running stress tests for new components, streaming videos for friends, etc etc. And my ocd self wouldn't want to look at a 34" monitor next to a 27" one. So its more just personal preference. But that will be further down the road once I decide what 1440p monitor to get.
Current Build;
Case: Corsair 6500x
34" UW and 27" are relatively close in size height wise, back before I moved and stuck to a single monitor since, I ran a 34" 1440p UW primary and 28" 4K secondary. Those were pretty close to the same height.
I would have the same, but you're likely running fullscreen windowed already to prevent weird issues with a secondary display, and its just as easy to alt+tab to look at discord quick than turn your head. Its just what I found myself doing instead, and I also noticed its a lot less distracting having an asymmetrical amount of extra light into one eye.
34" 1440 UW is also enough pixels to run multiple windows to multitask, effectively running two 10.5:9 displays which is really close to 4:3 in aspect ratio. That would be for scenarios where you're not gaming and want two browsers open.
I use multiple monitors at work though, but even then, I can accomplish the same tasks by simply using alt+tab. Its mostly because I use a laptop and a 32" 4K, but I could easy use just the 32" 4K for multitasking.
That makes sense, if I do decide to get an ultrawide then I would probably run it standalone for a while since I would have to get a different vesa mount anyways and who knows, I might get used to it.
Do any of those monitors that I mentioned sound like good values or ones to stay away from though?
Current Build;
Case: Corsair 6500x
Same, I run two 27" 1440p.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
I'm not sure 'good value' is easy to determine in today's market, since HDR on Windows works great now. You sort of get what you pay for, the only major variable being if you're willing to take the slight risk with OLED. Otherwise, Samsung's QLED VA panels are solid and getting heavily discounted, where my Neo G8 is on par with a mid tier OLED for contrast/color and isn't just marketed as HDR for the box like most budget/mid tier monitors.
Most 'HDR' displays on the market simply can't get the contrast necessary to run actual HDR, and just look washed out. In those cases, you're better running SDR.
I would narrow down specifically what specs/features you want, then see what the options are within that price range. Hypothetical, if getting acceptable HDR isn't worth another $300 but is worth another $100, then spending more might be a better 'value'. The specs in question being size, resolution, refresh rate most.
I’m looking to stay at 1440p and get a 34” ultrawide. And HDR isn’t a huge selling point for me as of now but more pixel response time, refresh rate, and panel technology. Which i know kind of go hand in hand. My only qual i guess is that most ultrawide 1440p monitors that I’ve seen in person (which isnt that many) just look very “weird” whether its the different resolution or whatever the case is. And the only one I’ve personally seen that is better is the Alienware AW3423DWF and Im guessing its only because its OLED.
Current Build;
Case: Corsair 6500x
A lot of curved ultrawides look weird unless you're directly in front of them properly. The more pronounced the curve is, the more severe the 'weirdness' is on any display. Once they're that big, its a bit daunting to look at until you're properly seated in front of it. The two I owned between 2016-2022 were like that, the second one having about twice the curve.
First gen OLED is a bit sketchy, but if you're confident that you can properly not leave it on for hours and shut it off when you're not using it (and it has decent burn in mitigation features) then you should be fine. I just don't trust the technology yet for a high power display, though its worked fine on the Steam Deck and smartphones now for like a decade. I have a sneaking suspicion that the extreme cases we've seen are people who clearly don't use the device properly.
