Would love advice on a basic Home Wifi setup
Damn, their prices and selection both suck. The only routers that support being a network controller on the site are the dream machine, dream machine pro, dream machine special edition, and the uxg pro.
The cheapest option is dream machine with two access points as it has wifi 6 built in. You will need POE injectors or a poe switch to power the access points.
The cleanest install is the dream machine special edition and 3 access points. The special edition has POE built in so it's one box and 3 access points, no messy injectors. You can add cameras if you want later as an added bonus.
The edge router is a fine product, but the one you selected is intended for wireless ISP (ubiquiti air max) devices. The problem with passive POE is it is can fry things that are plugged in that don't support it. With the edge router you turn poe on and off in the interface and it's up to you to make sure your devices are compatible. Active POE performs a handshake between the devices to supply the correct power.
