GPU Fan Mount Broke
Go to solution Solved by Average Nerd,
5 minutes ago, Ryeleigh said:
Can glue fix this?
With the right type of glue and some careful application, probably.
Bought a used GPU, its good for a week or so until I noticed it today that one of the fan is misaligned.
Upon closer look, the fan mount on the shroud broke. The fan still spin normally though.
Contacted the seller and they said just send it back to them, they'll take a look.
Now, I think its gonna be either one of these:
1. They gonna try to fix it themselves
2. Refund me
3. Change it to other units
It'd be nice if they changed it to other unit of same spec (GTX 1660 Super) since they are a second hand shop, but if they offer me a refund I'd probably refuse since I couldn't find another 1660S for 85-ish USD on my region.
Now question is, should I really send it back to them? Considering I'm really tight on budget (I need to cover all shipment) and the time required for shipment is probably going to take a week or so.
Can glue fix this? Also in case they offered me a refund instead.
Thanks in advance for any response.
https://linustechtips.com/topic/1561054-gpu-fan-mount-broke/
Can glue fix this?
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1561054-gpu-fan-mount-broke/#findComment-16339656
