Thoughts... General question
Honestly.... not a terrible CPU, probably won't get much performance boost until you also upgrade the memory.... CPU+RAM are probably the bottleneck, but won't be holding back your GPU too much.... split the build: get your trophy look now.... then make it trophy performance with a DDR5 build in a later step.
Just my opinion, but I hate to see people throw fairly serious amounts of money on old platforms that won't even get them some short-term good performance.... and push them down the path of wasting more money on older stuff later: by that I mean that 32Gb of white, RGB, high performance DDR4 is roughly double the price of the equivalent DDR5. (certainly for the TridentZ Neo DDR4 3600CL14 vs DDR5 6000CL30 - but I guess the performance on the 3600CL16 is probably closer and that is cheaper if you're just after the looks).
Old stuff is fine for extreme budget builds where you set your targets low, but not when you're spending this much money or wanting to pay for the premium-looking parts.
