Killing Floor 2 wont load
3 hours ago, Donut417 said:
Did that when it didnt work the first time. I ended up reinstalling the game. Still nothing.
Just installed new drivers. It at least flashed the Killing Floor start screen but nothing.
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor ($189.25 @ Amazon)
Motherboard: ASRock Fatal1ty B450 Gaming-ITX/ac Mini ITX AM4 Motherboard ($145.59 @ MemoryC)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory
Storage: Intel 660p 1.02 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($79.50 @ Amazon)
Storage: Crucial MX500 2 TB 2.5" Solid State Drive ($127.19 @ Amazon)
Storage: Seagate BarraCuda 1 TB 3.5" 7200 RPM Internal Hard Drive ($63.59 @ Amazon)
Video Card: XFX RX-57XL8MFGR Radeon RX 5700 8 GB Video Card
Case: Fractal Design Define Nano S Mini ITX Desktop Case
Power Supply: SeaSonic FOCUS SGX 650 W 80+ Gold Certified Fully Modular SFX Power Supply ($192.74 @ Amazon)
Monitor: LG 25UM58-P 25.0" 2560 x 1080 75 Hz Monitor
Monitor: LG 34WN80C-B 34.0" 3440 x 1440 60 Hz Curved Monitor ($635.99 @ Amazon)
Custom: Western Digital WD10S21X 1TB SATA 6GB/S 5.4K RPM 16MB SSHD Solid State Hybrid hard drive
Total: $1433.85
Generated by PCPartPicker 2024-03-01 21:35 EST-0500
This steam link had a user who had experienced the same problem as you. Some fixes were provided that might help you. The post is old though. For the first fix, find the KF.exe file in your steam folder where your games are. Right click, properties, and check box "run as admin". Some apps and games might not run without admin privileges. It varies. You can run the game via steam or through the exe file while steam is running.
https://steamcommunity.com/app/232090/discussions/0/618460129742006445/
