i own a rx 580 xfx gts xxx model which i bought seccond hand from a miner
the main bios doesn't show display so i use the seccond mining bios
how to flash the first bios so that it shows display?
system specs
windows 11 pro
cpu : i3 12100f
ram : single channel klev cras rx 16gb 3600 cl18
psu : cooler master 650 gold v2 full modular
motherboard : msi pro b760m-a ddr4 wifi
https://linustechtips.com/topic/1560608-how-to-flash-a-vbios/
Should be possible with the tools from here: https://www.techpowerup.com/download/bios-flashing/
If I'm not mistaken, their GPUz tool can export a vBIOS.
https://www.techpowerup.com/gpuz/
https://linustechtips.com/topic/1560608-how-to-flash-a-vbios/#findComment-16336733
i have both apps i just don't know how to bios it corectly
https://linustechtips.com/topic/1560608-how-to-flash-a-vbios/#findComment-16336740
