need help fixing my side panel
Solved by Blue4130,
1 minute ago, dreamcast4599 said:So I got my computer up and running but one of the metal bracket that holds the side panel in place came loose without using welding or soldering because I don’t have a soldering iron or a welder looking at the pictures below what’s the best way to glue it back together so it’s sturdy enough to be able to close the case Sorry those are the best photos I could take im wondering if this will work along with some claps to help it cure properly https://www.harborfreight.com/gorilla-glue-precision-glue-pen-with-fast-cure-97330.html
i dont have any tools for solder brazing welding etc
Two part epoxy would hold well enough.
