I seem to have lost control of my case fans
8 minutes ago, Skiiwee29 said:
That didnt work however the settings > edit sources did, not sure why, but it finally detected all of my fans, I have the CPU in the wrong one its on the pump header so ill swap them, but I was able to FINALLY get control of my 2 intakes and exhaust...
What a nightmare!!!
I dont know who to mark as solution, technically @RONOTHAN##I think got it in a DM, he thinks my cases hub doesnt have speed control built in, but I swore I had it all working before with my old case and motherboard, mind you my old case was quite literally the same type, I just grabbed the newer one to save some labor, as my BIL was getting my old motherboard anyway.
Not sure how I went from having full control on that one to none on this one but fuck it, RGB is working, speed control is working, eureka!
Edit: and in case anybody was wondering, Yes the hub that came with the case does work as when I unplug the fans they stopped running, and the RGB for the front fans is still working I re Daisy chained The hub back into the other hub to get the RGB to work so there's nothing wrong with the hub.
