I9-11900KF thermal throttling to 2.5Ghz with 240 mm AIO
The biggest problem with Intel CPUs is that the default voltage is set too high. Reducing the excess voltage can make a big difference.
I have a similar 10850K. It is a 14nm CPU just like yours but it has 10 cores instead of 8. According to the internet, it runs hot. After I adjusted the voltage I found that it does not run hot at all. I overclocked it to the same speed that a 10900K runs at. When fully loaded running Cinebench it only reaches 66°C. For cooling I am using a 240mm Corsair RGB PRO XT.
Try running Cinebench and see what HWiNFO reports for Vcore voltage. It is probably more than 1.3 V.
I reduced the AC/DC loadline values in the BIOS to reduce the CPU voltage. Have a look in the BIOS for this setting. With a pre-built computer, your BIOS options are probably very limited.
If you do not have access to the loadline settings then try using ThrottleStop to reduce your core and cache voltage. Post screenshots of the ThrottleStop main window, the FIVR and TPL windows if you need help. Turn on the Log File option when playing a game or doing any testing so you have a record of your CPU performance. Attach some screenshots and a log file to your next post.
