hi, i have just bought a new PC, and i only has a 250gb ssd no harddrive. i was wondering if its possible to install windows directly on to a fresh ssd without a hard-drive? any help in the matter would do cuse im really lost. all the videos and posts i found online people already have a hard-drive in when they change it to the boot drive or they have windows already installed in some way.
https://linustechtips.com/topic/155924-how-ssd-problems/
You can install windows onto an SSD like any normal HDD. If it's the only drive connected to the PC then it automatically makes it the primary boot drive in the bios.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/155924-how-ssd-problems/#findComment-2078476
Do you have a DVD drive? Do you have the Windows install DVD? I'm going to assume you do to simplify things.
  1. Make sure everything's plugged in (SSD included), and insert the Windows install DVD into your DVD drive.
  2. Turn on your computer
  3. If your computer boots into the install disk (you'll see the windows logo), you're good to continue
  4. Follow the on screen instructions, select the SSD to install Windows onto (it should be the only disk available in the menu)
  5. Continue following the on screen instructions, your computer will probably restart a few times
  6. Create your account, install all the updates, and you're set
  7. Remember to remove the DVD from the DVD Drive!
To Windows, an SSD and a harddrive are the same thing, it doesn't know the difference, because it doesn't matter to Windows.
Hope this helps, otherwise we can try to figure something else out :)
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/155924-how-ssd-problems/#findComment-2081559
