Temperature disparity between Aida64, HWinfo and AMD Ryzen Master
Tech Reprise
After I installed my new CPU I was monitoring my temperature in these softwares and I am seeing that the temperature in Aida64 for CPU is always higher than ~5C in idle. On load (Benchmark/Stress) they are within 0.5C of each other. Is there any setting in AIDA64 that can correct this behaviour as I use that for my stress test and temperature monitoring on desktop for max time?
Afaik AMD Adrenalin uses the same monitoring suite as Ryzen master so that can be taken as the Control.
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Ryzen Master only shows average CCD temp, while the others show an estimated "hotspot" temp called TCtl/TDie, which is always higher
HWInfo shows both, and you can see that the second line "average" is same than Ryzen master's temp
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
So which temperature should we tell people when they ask what my CPU temperature is?
  • Deepcool AK620 WH
  • Deepcool CK500 WH
Usually the higher one
So Aida64 it is for idle, as on load all show similar temps.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
