No, something you connect to a motherboard not for more control over fans, but for more fans instead of just two, like up to 10. Fan controllers only allow monitoring.
You can't put ten on this, but you're able to control fans via the hub instead of through the motherboard.
https://linustechtips.com/topic/155866-need-help-with-fans/#findComment-2077651
I don't really care about control over the fans... always on max and cool is good with me. I'm just trying to figure out the best way to connect fans.
and loud
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/155866-need-help-with-fans/#findComment-2077869
Why don't you just get splitter cables? And plug them all into the mobo.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/155866-need-help-with-fans/#findComment-2081125
https://linustechtips.com/topic/155866-need-help-with-fans/#findComment-2082807
