I always get very high power usage on my Pc. Even just watching a video on YT has a a very high usage. Should i upgrade my PSU --> what should i update to?
MY PC:
GIGABYTE GeForce RTX 4070 AERO OC - 12GB GDDR6X
NZXT n7 z590 lga1200
intel i7-10700
4x Corsair vengeance ddr4 rgb 8GB 3600Mhz
2TB Corsair MP600 Core XT
Corsair CX750F
NZXT Z73
10x Corsair QL120
i Have a corsair icue 5000X QL edition. What is the best layout for the fans. Maybe that is the problem?
https://linustechtips.com/topic/1558519-very-high-power-usage/
MY PC:
intel i7-10700
Corsair CX750F
NZXT Z73
10x Corsair QL120
Define "High"
Quote
No. Unless you consider extra 5-10 watts high.
Refresh before you reply
https://linustechtips.com/topic/1558519-very-high-power-usage/#findComment-16322779
How are you measuring the power usage?
What is the monitor that you're using?
What is "too much" for you?
Usually the PSU's efficiency has a very small impact on power usage, just a few watts when at idle and desktop.
https://linustechtips.com/topic/1558519-very-high-power-usage/#findComment-16322780
How are you measuring power consumption? A "Kill-a-Watt" type meter plugged between the outlet and your PC will give you an exact, real-time readout.
If you want something power efficient for watching YouTube videos, get an ultra-small PC, used laptop, or tablet. You're not going to save much by just replacing your power supply.
https://linustechtips.com/topic/1558519-very-high-power-usage/#findComment-16322785
I had a higher-than-normal power usage on my computer a while back. At first I chalked it up to my Intel Arc A770 having silly high idle power (40W T_T).
It also coincidentally turned out I had my PC plugged into a kill-a-watt meter to monitor how ASPM was behaving on that same subject, and it turns out it wasn't behaving good either so I disabled it entirely, but I digress.
I opened the task-manager and coincidentally had my eyes on my "kill-a-watt" meter, and noticed a sudden drop in wattage.
*That's odd*, I mumbled, and as I closed it, power usage went back up, an extra 35W. *scratching my head*
*repeat the operation* ... *same thing happens* ...
... tried using ProcessExplorer instead, and guess what I found ?
I had a rogue "Dlhost.exe" process (notice the spelling, I didn't make a typo, it wasn't dllhost) using roughly 30% CPU seemingly for nothing.
I killed it. It spawned itself again. It was controlled by a powershell script that would restart it automatically, and detected if taskmgr was running to hide itself.
Fun fact : it managed to register itself as an exception in windows defender, and indeed, windows defender didn't trip up.
As soon as I removed the exception, it started blasting notifications all over the place 😄
I had a fun ride hunting that f**ker down.
Turns out it was an xmrig clone mining a sh*tcoin when my CPU was idle (at least the author had the courtesy of running it at low priority -_-)
Fun story aside, I'll side with the previous posters : how did you conclude you have a high power usage ?
what are you comparing with ? higher than a lamp ? yes, that's normal.
higher than your microwave on maximum power ? not so much indeed ...
https://linustechtips.com/topic/1558519-very-high-power-usage/#findComment-16323049
If you talking about this
Ignore it.
https://linustechtips.com/topic/1558519-very-high-power-usage/#findComment-16323106
