PCIe cable question
Solved by seon123,
52 minutes ago, eggowlred said:do I need to upgrade my PSU to support PCIe gen 5 power adapters or will I be fine
No, you don't even need an adapter. This one from Corsair is compatible with your PSU. Do not just get any random 12VHPWR cable, as that might fry your graphics card.
Just make sure to plug one connector into one labelled VGA1, and the other into one labelled VGA2.
