Limited amount of case fans, wondering where they should be placed
Solved by IkeaGnome,
12 minutes ago, EL86 said:I was wondering either what the best placement of the additional 2 fans would be
Front.
12 minutes ago, EL86 said:or if I should just buy a fan hub and install a fan in every available spot.
Would always be ideal, but you don't necessarily need a hub to get 5 fans in a case.
12 minutes ago, EL86 said:I'm also looking for any good budget fans (120mm), so any suggestions would be great.
Arctic P12 price to performance is hard to beat. Especially when they don't need a hub.
If you wanted RGB it more than doubles the price to fill the slots.
