Be quiet power supply
AlecM
How is the Be quiet Pure Power 12M?
The whole pure power line is designed as a product to be the most middle of the road choice possible. There’s no way of describing them other than “perfectly adequate”.
You lose features that the higher end dark power units have, both in technical features and physical componentry. But then you have none of the cost cutting measures that the lower end system power line has.
Theyre the irrevocable baseline of “average”.
I mean theyre not warrantyless (<10 year warranty) and there doesnt seem to be any issues with them
assuming theyre priced decently and there isnt a cheaper unit with similar/better quality that retains the 10 year warranty its a decent pick
