i damaged my LED mon with tn panel while cleaning it
http://i.imgur.com/IHNDlc6.jpg
there are 3 darker spots there is one at the middle in photo they are annoying when doing something in white area
https://linustechtips.com/topic/15575-screen-with-a-dark-corner/#findComment-177697
Can you show a picture of the issue, please, so that I can diagnose the problem.
Uniform back light does not exists in the consumer market, as it's a very costly, and most users don't see the difference.
However, high-end consumer grade monitors have, usually, much better light uniformity than low end monitors.
https://linustechtips.com/topic/15575-screen-with-a-dark-corner/#findComment-177754
Usually you a monitor doesn't break when you clean it, unless your cleaning process involves using excessive force on the panel.
These dead pixel were most likely there, and you just noticed them as you cleaned the screen.
https://linustechtips.com/topic/15575-screen-with-a-dark-corner/#findComment-177762
excessive force ;i was almost sanding down this monitor at the time of cleaning  <_<
https://linustechtips.com/topic/15575-screen-with-a-dark-corner/#findComment-177785
