Need help understanding what I'm missing?
Hello Everyone
Need some help, Built my 8 year old son a PC like 8 months ago. It's driving me ultra crazy!
Specs:  I5 10600K
             Asus Tuf B560M-plus wifi LGA1200
             16 Gigs Ram
             RTX 2080 super 8 Gig
             Benq monitor using HDMI 60Hz refresh rate max for that monitor
Here is the issue: Runs fortnite like garbage max FPS 25 on low settings, med settings 15 FPS max, high settings not playable!? laggy as bleep, I've updated all the drivers, bios.................
I checked the bios settings everything looks ok.
I was going to buy a new LGA 1200 motherboard but can't find any at a good price. not about to spend $300 on a used one off ebay or amazon.
I just don't get it
Any ideas?
https://linustechtips.com/topic/1557441-need-help-understanding-what-im-missing/
To rule out a problem with that specific game, I'd run a benchmark for the CPU like Cinebench and one for the graphics card like Timespy and then we can see which one is the problem.
What is memory usage like while playing Fortnite?
You have checked temperatures, I assume?
Double check all the simple stuff if you haven't already as well. Make sure you have drivers installed, I would recommend getting them from nvidias website. Also double check the game isn't trying to run on integrated graphics instead of the actual GPU.
My Rig: AMD Ryzen 9 5900X 12-Core 3.7 GHz Socket AM4 105W || NZXT - Kraken X62 Liquid CPU Cooler || MSI MAG X570 TOMAHAWK WIFI AM4 AMD X570 SATA 6Gb/s ATX AMD Motherboard || CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) || SAMSUNG 980 PRO M.2 2280 1TB PCI-Express Gen 4.0 x4 || SAMSUNG 970 EVO PLUS M.2 2280 500GB PCIe Gen 3.0 x4 || Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive || MSI RTX 3080 GAMING Z TRIO 10G LHR || Fractal Design Meshify 2 Black ATX Flexible Dark Tinted Tempered Glass Window || Seasonic FOCUS GX-850, 850W 80+ Gold, Full-Modular || Microsoft - Windows 10 Pro OEM 64-bit || Logitech - G502 Proteus Core Wireless Optical Mouse || Input Club K-Type w/ Ajazz Kiwi Switches
  • 2 weeks later...
