Sandisk 1Tb Extreme Portable SSD 1000x Smaller Than it Should Be
This SSD says that it is 127 Mb's when I click on its properties in Windows, I know it used to be a 1Tb drive, but after I had to use it to
I have this Sandisk 1Tb Extreme Portable SSD and it shows up in windows as a 127mb drive. I have used it in the past and it was larger then. The only thing I have done with it recently is use it to reflash my Steamdeck with SteamOS. I tried using a usb stick for that, but it was taking hours so I redid it wiht the SSD. How do I make the SSD go back to what it was before? The drive's name is "EFI", but when i go to Properties>Hardware it has the old name of the drive. If anyone need screenshots or other information please let me know this is like a $90 drive. Thanks in advance!
Have you checked in Disk Management if the rest of the drive isn't simply unformatted? If it is, you'll see the F: EFI partition in blue, and a black bar besides it with the rest of the storage. Just right-click on the blue bar and then "extend volume".
I would check disk management instead, might need to delete a volume the Steam Deck created that Windows doesn't recognize.
Ryzen 7950x3D Direct Die NH-D15
RTX 4090 @133%/+230/+500
Builder/Enthusiast/Overclocker since 2012  //  Professional since 2017
I agree with the earlier posts.
What you are looking now, is just a partition, not the drive as a whole, you just have to go to disk management, to see the whole device.
And I would just initiate it whole in GPT and then create a partition on it.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
