Backpack and extension questions
There is a full overview of your backpack's features (including usage suggestions) at the bottom of this page: https://www.lttstore.com/products/backpack
By "strap extension" I assume that you mean this? https://www.lttstore.com/products/magnetic-chest-strap To use your new chest strap, you need to remove the old one from your backpack. On the lower part of your backpack's shoulder straps (pic below), there are two flaps with fabric loops underneath that your chest strap hooks onto.
To remove the original chest strap, slip that fabric loop through the gaps in your chest strap's clip (another pic below), then repeat that process on the other side.
To put on your new magnetic chest strap, do the reverse of the above.
