Help with Motherboard
17 minutes ago, Displayname9000 said:So I got that psu from my teacher that Cryptomined (I've bought from him before so I trust him on the components). I do however use 500 watts for my build, not 1000w. So I was thinking of maybe selling it to buy a cheaper PSU and using that money for more RAM or SSD. I do like the recommendations you gave on the GPU since I do want to play games at 1440p (Fortnite only) with high frames but I don't know anything about GPUs. I did spend more on the CPU since its main use would be only for work, school, editing, and YouTube but do you have any recommendations for more GPUs?
Used psus are basically worthless so you wont be getting more than 80$ for that 1000w rmx, hence why i reccomend buying used psus for more budget builds since you can get quality for 40-60$ instead of a new trash youd get around that price that has no wattage (no futureproofing) nor any warranty (<10 years)
3080(ti) go for around the same price as the 6900xt/6950xt though less vram
15 minutes ago, Displayname9000 said:also... where should I buy used gps that are more trustworthy from sellers?
You simply test the thing yourself before buying
If you can buy through an eshop that has good customer protection that also works cause if its broken you simply file a complaint and get your money back
Here in indo i have tokopedia so if i buy a gpu or whatever part and it turns out broken i simply file a complaint and wait for my money to be returned, though there are better deals on facebook from time to time which may not be able to ship to you so you have to come in person which i havent done before and likely wont for the forseeable future
