Evga 500GD Surge protection
Solved by OhYou_,
sure, most power supplies and any real surge protector contain whats called a MOV, metal oxide resistor.
it's job isnt to exactly protec your equipment, instead, what it does is just EAT the voltage spike.
In doing so, it pulls a ton of current and should trip a circuit breaker.
if you did not have to reset any breaker or reset the switch on your power strip, there either was no spike, it wasnt significant enough to cause damage, or the MOV is worn out. They only last a few surges.
