Help me I split my 8tb Nas Drive into 2 3.7tb partitions!
Solved by Zando_,
4 minutes ago, Dedayog said:Which is what you'll need to do anyway, after you CMD the partitions away and reset the drive.
^^^ Admin cmd, diskpart, list disk, sel disk (whatever # is the one you want to wipe), clean (this will nuke the drive, do not run it on something you care about by mistake), exit CMD, yay your drive is back to a single blank and you can format it however you wish.
Featured Topics
Spencer The Mid ·
Posted in Hobby Electronics0 -
Eurimeee ·
Posted in Troubleshooting1 -
2
2
monkk ·
Posted in Networking4 -
1
