amd cpu is using more and more power when its hot and hotter. why?
Solved by porina,
Not sure what I'm looking at in those screenshots.
In general, there is a phenomenon with silicon called thermal runaway. In short, the hotter it is, the more power it uses to do a certain thing, which means it gets hotter, which means it takes more power. Repeat until either the magic smoke escapes, or some safety mechanism kicks in to stop the cycle. On CPUs, that would be thermal limiting as a last line of defence.
