Electric noise on my iem
Guest
I just installed windows 11 on my laptop and my IEM has electric kinda like coil whine noise, when im still on windows 10 updating the driver is enough to fix the issue, but now after updating the driving nothing change
The laptop im using is legion 5 2021 (15ach6h), the iem im using is kz zsn pro x.
When there's a 'electric' kinda sound, it mostly caused by the hardware of the product
Either the IEM or the jack port (DAC) on the laptop is the cause of the issue
Have you tried to use other IEM on your laptop?
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
I only have 1 pair right now, and i dont have other wired audio device maybe i can borrow my friends iem.
I havent tried my iem on other device but i'll try it later, after i found a device with 3.5mm
You could get the $9 Apple USB-C to 3.5mm headphone amp/DAC as a quick fix (and very good quality!). If there's still noise then there's something wrong with your buds.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
