$ 1500 CAD build ( i made a parts list already please just review it)
31 minutes ago, covid19king1 said:I was gonna go with the b650 but i (for not related reasons) need wifi and it would be another $50 for a good wifi card. Would the b650M be ultimately worth it?
Did not realize that the A620 board had WiFi. I still probably would try to go for the B650M option if possible, worst case scenario you can just use for phone as a WiFi adapter for a month or so until you can either get a cable run or afford a WiFi adapter, but if that's a little jank for you I wouldn't blame you for going for the A620 board.
PBO and upgradeability are the main reasons to have the B650 over the A620, since PBO should give a couple percent more performance, and the A620 boards have really weird issues with higher power draw CPUs. If that couple percent of performance doesn't matter to you, and you never plan to upgrade the CPU, the A620 board is fine, otherwise I'd spend the extra on the B650 option.
