noise cancelling mic Seeking a way to filter out microphone background noise/clutter at the interface level
1 minute ago, BigDashT said:(something that allows me to feed my microphone input directly into something like Krisp then output it as a virtual audio device would be amazing)
So RTX Voice? Everything you're describing, at least to me, sounds exactly like what RTX voice is designed to do. The only downsides to it is that it requires the use of a Nvidia GPU from the 900 series or newer, but that can be had for next to nothing on the used market these days and it's incredibly good at reducing input noise. Pretty sure it's now bundled into the Nvidia Broadcast program rather than standalone like it used to be, but it still does work.
AMD also has a version of it that works the same way, though theirs is no where near as good, and it should only really be considered an option if you already own a semi recent AMD card (RX 470 or something) you can test it with for free.
Both of those are free as long as you own the respective GPUs, so consider that the license fee.
