Compressed Air Cleaner Question
Go to solution Solved by Levent,
3 minutes ago, ChrisLoudon said:
Recently got exactly that. I’m really happy with it.
Hi guys,
Over the years I've gone through many a canister of compressed air so was wondering if anyone here had a good suggestion for a battery or mains powered version.
Loads of options on Amazon but not sure if they are any good.
Any recommendations would be greatly appreciated.
Cheers
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1555087-compressed-air-cleaner-question/
2 minutes ago, jaslion said:
Like you want an air compressor or just something to dust your pc out?
https://www.amazon.co.uk/WHATOOK-Electric-Compressed-Duster-Cleaner/dp/B0B88D1H52/ref=sr_1_8?crid=32Z1NZYYZ2I93&keywords=compressed+air+cleaner+for+pc&qid=1706437924&sprefix=compressed+air+%2Caps%2C81&sr=8-8
Something like this but wasn't sure if they are any good.
That's exactly what I wanted to know.
Cheers
14 minutes ago, ChrisLoudon said:
Yeah these are just generics. I dont expect the battery to last too long as in time before its dead and swells up so I'd just opt for a cabled only one. They are all generics so pick a 5 star one and hope for the best. The one I bought some years ago vanished a week after I got it 😛
1 hour ago, ChrisLoudon said:
Hi guys,
Cheers
C
The compucleaner is great
IT Dusters CompuCleaner Original Electric Air Duster Blower for PC, Laptop, Console, Electronics and Home Cleaning, Environmental Alternative to Spray air can Duster Keyboard Cleaner compucleaner : Amazon.co.uk: Stationery & Office Supplies
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
We have a DataVac duster at work, probably the exact same one Linus and Jake used when they rebuilt that Storinator a couple years ago. It's heavy and loud, but exactly what you need if you have a lot of equipment to dust off.
Personally, I just use my air compressor. It's this one from Harbor Freight. It isn't enough to run a paint sprayer, but it can run air tools and inflate tires, which is all I really needed it to do anyway. (I don't like power tools that are only good for one niche use case unless they're exceptionally good at their job.)
A leaf blower can also do a good job of dusting computers out. Just point it away from the computer and run it for a bit first if you ever used it as a mulcher-vacuum.
I recently got an XPOWER A-2 Airrow for $35 used on ebay, feels very well built and it cleaned my machine quite well. There seems to be a good secondhand market for them. I was just a bit cautious with the fans and watched to make sure I didn't get them spinning too quickly, not sure if it would cause any issues with electricity generation or not. Seems like it would also double well as an air mattress inflation device.
I use a Metro Datavac ED500. Works awesome.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
I use one of these to dust out server cabinets and such at work.
DEWALT 20V MAX Blower, 100 CFM Airflow, Variable Speed Switch, Includes Trigger Lock, Bare Tool Only (DCE100B)
PRAISE THE LORD AND PASS THE AMMUNITION...
EVGA X299 Dark, i7-9800X, EVGA GeForce GTX 1080 FTW2 SLI
I just bought one of these: https://www.amazon.co.uk/dp/B0C8C8LDN1?psc=1&ref=ppx_yo2ov_dt_b_product_details
It's alright for the cost but not great, gets the bulk of dust out and is re-chargeable with multiple attachments and 3 settings.
[UK]
🔸 Intel i7 6700k 🔸 ASUS Z170-A 🔸 64GB HyperX Fury 🔸 GeForce GTX 1080 WINDFORCE OC 8G 🔸
