Help me identify this exact card
Solved by jaslion,
30 minutes ago, AllaboutBudget said:I just want to be sure that I get to maximize the card's longevity
I mean the carda die far before the pads go bad.
Its far more likely that you changing the pads will do harm to the gpu.
With gpu's its best to just not open em if not needed
Featured Topics
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2 -
1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
