Bookshelf speakers / Amp help please
gamermum12
Hello everyone!
I need help in choosing some bookshelves speakers; I 've never had speakers to own in my life. I’ll be using them for multi-purpose for games, music, movies. I’ve always used headphones/IEMS especially the HD 660s, My budget is $100.
I would appreciate any recommendations. I am looking for something more neutral frequency, if i could get a speaker experience that is like HD 600s that would be perfect. I don’t have a preference when it comes to being active or passive speakers, just looking for that perfect sound. Thank you.
Out of these choices what would be the best? (most neutral?)
If i have to go passive i don't have a lot of money to spend. I have found this amp nobsound on amazon is it any good for what I'm trying to achieve?  Will it drive the Neumi BS5?
https://www.amazon.com/BS5-Passive-Bookshelf-Speakers-Tweeter/dp/B07YZDS9LF/ref=sr_1_6?keywords=NEUMITECH&qid=1706396209&sr=8-6&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
https://www.amazon.com/Edifier-R1280T-Powered-Bookshelf-Speakers/dp/B016P9HJIA?ref_=ast_sto_dp&th=1
https://www.amazon.com/dp/B08CD2Q9G1?ref=ppx_yo2ov_dt_b_product_details&th=1
https://www.amazon.com/Singing-Bluetooth-Bookshelf-Auxiliary-Finish-Pair/dp/B08G6MWL5L?ref_=ast_sto_dp&th=1
https://www.amazon.com/dp/B06Y67PZB1?psc=1&ref=ppx_yo2ov_dt_b_product_details
7 minutes ago, gamermum12 said:
Hello everyone!
This has 4 selections all at $100. Each one would fit the bill nicely.
I'm sorry to tell you that for $100 you're not getting anything that will sound as good as your HD660's, speakers start getting really good around the $300 mark and under that kind of budget (as much as i think that 660 are the worst of the 600 series of headphones) i'd still much rather HD660's than speakers under JBL 305/ Kali LP6 prices (you need to buy a pair of 305/ LP6's and they're where speakers start outperforming headphones from my experience)
At this price point, go for used. Passive speakers last for decades when they are not abused and there are loads of really nice speakers out there that you can buy for cheap because they are old. Just make sure you test them before you buy.
If it was my budget I would show brand loyalty and go with the edifiers.  That or give Micca a try for a little more, they're a brand that is really good at small speakers.  I have the passive version of the ones I linked and for being so tiny they are amazing..... though I have a really strong power amp behind them because the passive version is not efficient at all and soak up a ton of power. (I can't say that the powered version will be anything like the passive, but I have a hunch that they will do a good job at it)
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
