Elden Ring FPS Unlocker low GPU/CPU usage and less than ideal performance
Solved by jaslion,
17 minutes ago, SpookyCitrus said:FPS for a 5800X3D and 4080 system with FPS unlocker has an average of around 145fps at 1440p on max settings. It's possible you have some sort of bottleneck with the 3900X but I don't think it should be that drastic, your GPU utilization is pretty low. I'd recommend using DDU to remove your GPU drivers and install the latest available using GeForce Experience. Also check the manufacturer support page for your motherboard and do any Bios or driver updates available there as well. Make sure DOCP/EXPO is enabled. If none of that works then there is some other issue.
Also pbo because the 3900x is usually quite tame until that goes on
