Problem with Linux Mint 21.3 - could not download all respository indexes
Solved by E-waste,
8 hours ago, YellowJersey said:is not valid yet (invalid for another 6h 10min 41s).
Your system clock is off. I had the same issue recently. Keep your PC plugged into power at all times to keep the CMOS battery from needing to drain itself, and consider using NTPd or similar to manage and maintain the system clock if this continues to be an issue. There is also chrony, which when set to use rtcdrift file, will keep up with the clock drift since last reboot. It's all commandline and takes a while to figure out, but avoids these small issues. The archwiki has great example setups on chrony to use the rtcdrift file if you'd like te set it up.
