Just now, NecaTheGod said:
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): RX 6600 xt and i-5 12400f
Are these desired parts or pre-existing?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
2 minutes ago, NecaTheGod said:
Desired
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€122.99 @ Mindfactory)
Motherboard: Gigabyte B550 GAMING X V2 ATX AM4 Motherboard  (€106.90 @ Amazon Deutschland)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€65.90 @ Alza)
Storage: *KIOXIA EXCERIA G2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€49.99 @ Amazon Deutschland)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card  (€358.90 @ Alza)
Case: *Zalman S2 ATX Mid Tower Case  (€35.90 @ Alza)
Power Supply: *EVGA 600 BR 600 W 80+ Bronze Certified ATX Power Supply  (€53.90 @ Alza)
Total: €794.48
Generated by PCPartPicker 2024-01-15 13:26 CET+0100
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Total: €794.48
Are cpu coolers not necessary or?
And which monitor would be good (mostly like 24 inch)
The Gigabyte B550 GAMING X V2 ATX AM4 Motherboard supports the AMD Ryzen 5 5600 3.5 GHz 6-Core Processor with BIOS version F14. If the motherboard is using an older BIOS version, updating the BIOS will be necessary to support the CPU. What does this mean ?
the cpu comes with one
don't worry, it's just pcpp annoyed at the bios version but it should come updated. Even if it doesn't, the mobo has bios flashback so it's really easy to update the bios (with a usb stick)
Included in the budget?
try this
AOC 24G2SPAE/BK 23.8" 1920 x 1080 165 Hz Monitor (24G2SPAE/BK) - PCPartPicker
Total: £1040.95
try this
Tysm u helped me so much🥰
Btw if i order pc from pc part picker does it come assembled or not?
