Hi all,
I'm looking to do some custom sleaving on my power supply I have everything ordered to do the whole thing. The only question I have is the sata power. Can I mod the cable and have all the sata power connectors on one line, as I have 5 HDD's all next to each other and I think it's the only way to make it look clean. But I don't want to break my PSU by doing it, is this something that's possible?
Freelancing Since 2012
https://linustechtips.com/topic/15522-non-modular-cable-sleaving/
Hi all,
do you mean something like this?
to the right of the pic are the sata power cables.
all of them are one cords with multiple sata power connectors stemming off from it.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/15522-non-modular-cable-sleaving/#findComment-178507
I have the Corsair CX750m PSU and i wanna sleeve my cables, from what i've seen it looks like you take the PSU shell away, on mine theres 4 screws on the top but i'm not going to do this until i know that my PSU works :P
I've hard that if you take the shell you sometimes have to make the hole for cables bigger as it's hard to pack them back in tight. Just something to think about if your not comfortable with metal work.
"An Excellent Signature"
https://linustechtips.com/topic/15522-non-modular-cable-sleaving/#findComment-180845
