Surface Pro 4 Battery / Power Issues
Go to solution Solved by jaslion,
They had battery drain and charging issues since day one
Probably the batteries are swellig right now so a danger to use! Chrck if the laptop is buldging
Dont buy surfacr laptops again just buy some proper bussiness laptops like hp probooks, lenovo p series NOT DELLS THEY SUCK!!!!! or whatever as those are made to have relatively easy maintenance and parts replacement done. Also often cheaper for better devices.
The batteries are user replacable for the ms laptop but like in almost any consumer they suck to replace due to being difficuly to access. Built to be disposed literally also no reason to opt for long lasting parts as well you should toss these out after a year or 2 at most preferably for microsoft.
Work in it admin and wiping/disposal of devices. We know what comes in the most here and the age of the device which tells us yeaaaah these microsoft products are shortlived usually and scrap. Cept for the surface pro 3's and 4's those still come in from time to time but they are OLD and used for a long time. Most of the bussiness laptops come in after 3-5 years (usually more near 5 or longer since they tend to get a second life firstly). consumer stuff usually 3 when in big batches (aka an organisation used a lot) individual laptops come in at later ages usually (when I mean that they dont have obvious impact damage n stuff)
Hi guys,
I have 5 MS Surface Pro 4 Laptops that I've been using for my business for a number of years now, and while the core specs of these systems still serve me well for what they are being used for, I am having issues with ALL of them when it comes to battery and charging.
1. When plugged in to charge its hit and miss as to whether it will charge or just sit there indefinitely at 0% and run from the power brick. Pulling out the cable obviously causes the system the to immediately power off. Repeating this process a few times usually kicks it into shape.
2. When plugged in, the track pad has a mind of its own. The mouse curser freezes or flitters about. A BT, wireless or wired mouse works fine.
3. The battery life percentage rarely bares any resemblance to reality. It can report 50% and it doesn't matter if I decide to unplug the charger OR plug it it, the system can just turn its self off.
If its just old age and I need to replace them the happy to do so but if anyone knows of some cheap and easy battery 'hacks' that can breath some life back into these guys then great.
Cheers
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1552183-surface-pro-4-battery-power-issues/
