Hello I need a little help deciding what to go with building a custom hard line set up. I'm using a new amd am5 chip, the only things I really care about aesthetically is id like to use a reservoir with rgb and maybe use frosted hardline tubing. I'm not interested in a aio I want something that looks really cool. Is there a pc part picker like website I can easily layout everything I'll need to order?
Specs
Amd Ryzen 9 7900X3D
ASUS Prime 650 Plus
Thermaltake tower 500
https://linustechtips.com/topic/1552044-need-help-hardline-cooling/
Specs
Amd Ryzen 9 7900X3D
ASUS Prime 650 Plus
so you wanna do custom water cooling but without the custom?
if you need help picking components you're not ready for hardline
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
this.
even an AIO isn't really needed these days , and people are out here trying to do hard line without any experience at all.
it's really hard to convince people you can just aircool a computer when you got youtubers literally being paid to sell them AIOs for every single build regardless of what they need.
