Hello there.
I have 5x 480mm XE rads in one loop for a CPU, one pump on each end of the loop, so two pumps. They all cool only one component the CPU. Water in and water out for the CPU has quick connect on each side.
Will it impede water flow so much that my temps and radiator space won't matter?
I don't have a flow meter, and I'm contemplating buying one
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1551695-does-quick-connect-limit-my-temps/
3 minutes ago, TheNaitsyrk said:
Hello there.
depends on the quick connect to be honest.
i used some of those alphacool HF quick connects and flow was awful. i swapped them our for koolance QD3's and everything has been fine ever since.
5 minutes ago, TheNaitsyrk said:
Hello there.
To be honest, i think the main thing limiting you isnt flow rate but ambient temperature, theyre such big rads that the water is probably close to room temp by the second rad, maybe running the cpu on cinebench for an hour it might not be cool until the 3rd rad but i dont think at the VERY least that the last rad is doing much of anything bar impeding flow tbh, i could be wrong, but i think the issue isnt flow rate imo
But not gonna lie, dont know enough about water cooling to tell you about the quick connects or if having that many rads will actually help or not
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
Not in a way that will matter in the slightlest.
Basically your loop is so beyond overkill for even a 14900ks it wont matter at all.
Dont drop convenience for like 0.001 degree difference if there is even because well you gotta have a pretty darn powerfull pump to be flow limited and desktop watercooling pumps aint that. Unless you have a garbage special quick connect.
If you want colder temps you need colder water and probably if you disconnect 4 rads the temps on your cpu will simplt be the same. Its because so much heat exchange can happen that by the time the water leaves the rad its most likely at or near room temp again.
Since you can't really make heat exchange between the cpu nd waterblock better (the real bottleneck really) because thermodynamics n stuff the only way to go colder is go colder than ambient which I DO NOT RECOMMEND because condensation kills all electrical stuff.
That's my loop, quick connects are QD3s
Main PC:
Case: TT P3
HTPC:
4 minutes ago, TheNaitsyrk said:
That's my loop
Wait are these in series? As in one after the other with no fresh air in?
That has basically the same cooling performance as 1 rad since there is no cold air comnming into the system eventually the air inside of thisbsystem will equalize to whatever is the coldest air that came out of the first rad
Sorry just saw they were flipped my bad
Anyways this is so much overkill nothing matters here. You can have crap flow it will still be darn fine.
You'd ebtter have a beefy af pump or even 2 inseries here tho 😛
One D5 pump at the beginning and one at the end of the loop
Main PC:
Case: TT P3
HTPC:
The problem that I'm having is at LLC7 1.4V which is about exactly 1.359V under load (as per CPU-Z) and Core Temp shows exactly 420W of load. My temps start at around 78-80c hottest core 83c and then it ramps up to about 87C (85c average) under extended CB23 load 6.0 and 4.8Ghz.
Some people I know have LLC8 1.390V which is probably like 1.41V in CPU-Z gets the same temps.
My ambient is 20c same as his. Trying to understand what I'm doing wrong here. Should I buy a flow meter?
Main PC:
Case: TT P3
HTPC:
Colder water = lowering ambient temp or stright up hooking to a chiller
Chillers are kinda meh cause too warm and condensation risk then you look at phase
Single stage too warm to keep completely under 0 (aka becomes pointless)
Next thing you know you are building a cascade system or dissassembling and modding a cryocooler and you are looking at days if not weeks worth of physical work, research, etc. a very power hungry cooler, -100c and under load temps, hundreds if not thousands of $ burnt, but 7ghz+ all pcores at 1.6v+
If you dont go straight up -100c cryocooler only other options are to keep binning more cpus or set your ac colder for lower ambient temps
Honestly id just settle if i didnt want to go out and build a cryocooler just for the cpu, 6ghz pcores and 4.8ghz ecores is already pretty decent
Yes i know diehards hate settling (ask me how i know and why im imc binning bloomfields + gulftowns) but there really isnt any other way at this point, you are stuck with lowering your ac temp for lower ambient temp, binning more cpus, or building a cryocooler, and only one of those seems to be the most feasable and that is lowering your ac temp
Its actually better to put them directly in series as that is far more efficient to create head pressure. That can be a fun lil "upgrade" 😛
Quite literally you are at the limit of what 20c water can do. There just isnt enough of a temp delta.
Also you are under 100c so totally fine.
Keep in mind no cpu is equal and that also means no heatplate or solder job is equal. There are a bunch of variables here that can increase temps. I highly doubt its your loop.
If you want more water blasting through even harder just put the pumps in direct series (and make sure they run as close to same rpm as possible) and see what that gives.
You're on the bleeding edge here. Simply running into never accounted or tested for situations so variance is normal
I'm on direct die. Same way to cool.
Main PC:
Case: TT P3
HTPC:
No chillers thanks
Main PC:
Case: TT P3
HTPC:
Yeah you're simply at the limit and luck of the silicon lottery and minmaxing the super ultra tiny gains in the waterloop that wont really matter at all.
You've pushed your hardware about as far as possible in the constraints you put and theres little to nothing else to do.
It was never built to be in this shape and is thus tested within the manufacturers tolerances. Which can mean that you get these variations when pushing them well past normal circumstances.
I will test today with additional pump, as much as I think you're correct it will put my mind at ease
Main PC:
Case: TT P3
HTPC:
is there not a website that sells bined cpus? if you dont care about moeny just spend some and get a bined one.
My one is already binned, that website went bust btw
Main PC:
Case: TT P3
HTPC:
