PSU/Gpu mobo problem?
Go to solution Solved by Pnshr1337,
9 hours ago, Godlygamer23 said:
Much of the same circuitry is being used with the CPU as well as the graphics card. If the power supply was damaged, I would expect some weirdness on the CPU side if anything was damaged.
With that being said, I would look inside the power supply anyway for any kind of damage, and if you're comfortable with it...taking apart the graphics card to see if anything is damaged beyond what can be seen with it assembled.
Thanks for the reply and the help. God bless 🤘
12 hours ago, Pnshr1337 said:
So you think its not the PSU? Because then it would have stopped working during prime 95?
That's the theory.
I mean a shock like this the bond between the thermal pads and the heatsink on the GPU could have been disrupted, causing the RAM or VRMs to overheat, which would explain why it works for a while then fails.  It may be fixable if so, but taking apart a GPU IMO is kinda stressful, especially trying to find replacement pads of exactly the right thickness.
9 hours ago, Alex Atkin UK said:
That's the theory.
I live in Dubai and computer shops over here are pretty clueless when it comes to repairing. I think i am gonna buy a budget gpu. Anyway thanks for your time and reply. Appreciate it man. Thanks
