PSU/Gpu mobo problem?
Solved by Pnshr1337,
9 hours ago, Godlygamer23 said:Much of the same circuitry is being used with the CPU as well as the graphics card. If the power supply was damaged, I would expect some weirdness on the CPU side if anything was damaged.
With that being said, I would look inside the power supply anyway for any kind of damage, and if you're comfortable with it...taking apart the graphics card to see if anything is damaged beyond what can be seen with it assembled.
Thanks for the reply and the help. God bless
