Repair a Storage Pool with a Degraded Status , have to contact Seagate for warranty ? or can fix ?
Solved by PSP.,
1 hour ago, Needfuldoer said:F
I hope you've got backups, @PSP. Feed it a drive that meets the specs it's asking for and let it build a mirror. Then once it's fully copied, you can pull the questionable drive and either check its health with another computer or try plugging it back in and see if it will resilver successfully.
backup up everyhing daily all good have portable hdd
but idk talk B&H or Seagate themselves ?
confirmed hdd itself
slot switch as image
when I read pool guessed can solve or software issue
