Massive audio delay when starting videos on my HP Omen Blast Headset when on USB
Solved by DandyMan,
I've managed to find a fix in the end, not sure if this is the proper solution or the best solution, but with my non-existent knowledge on the matter it was the best I could do and so far it seems to work great.
To anyone reading this in the same situation as me where no other solution has worked (even the regedit fix because like me you don't have a Realtek audio driver) give this program a shot, make it run on startup and minimized to tray (cause the solution only works if the program is opened) and you're good to go.
