Thermal paste aplication and removal
Solved by ChaoticChaosx,
Just go with 70% if you can. Doesn't make much of a difference. I use a coffee filter and 70% isopropyl alcohol for both my waterblock and CPU. Works fine. I'm currently using thermal grizzly kyrosheet on a 7800X3D after going from a 3900X. Due to the little cut outs on the new 7000 Ryzen CPUs. Don't want thermal paste getting in there. Spread or not. Not a big deal but rather not deal with it. First time using it and temps are about the same never above 72c (max) in gaming then around 40c - 42c idle. On water though playing a factor of course.
