Ok so here is the deal,
I currently have a Fractal Design Arc Midi R2 case with the stock fans, however I am looking to buy some case fans and I am unsure of what fans to get.
So I was initially thinking of running Noctua Fans as the front fans because they are low noise, efficient and can't be seen(not a fan of the colour scheme).
However I don't fancy having noctuas as the rear exhaust and upper fan. Was thinking the Corsair AP Quiet Edition fans but I've heard they are not exactly that quiet. I would like them to look good however.
What fans would you recommend?
Thanks in advance
https://linustechtips.com/topic/155038-case-fan-advice/
Noctua Nf-f12
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/155038-case-fan-advice/#findComment-2066684
The black noctua fans coming soon. What color scheme are you going for? All black? And yes the corsair fans are quite loud.
https://linustechtips.com/topic/155038-case-fan-advice/#findComment-2066692
If you want quiet fans, then Corsair's fans aren't the way to go. Maybe some NB Black Silent Pros. I recently bought some and they're extremely quiet. Just keep in mind that specs of a fan aren't always accurate, look for an actual test and review of them (:
https://linustechtips.com/topic/155038-case-fan-advice/#findComment-2066700
Thanks in advance
Forget corsair fans, get Noiseblocker black silent pros, they cost around the same and blow the corsair fans out the water in terms of performance/volume.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/155038-case-fan-advice/#findComment-2067584
Cheers guys, will have a look at the noise blockers any particular version, 120mm/140mm either one. Are the Noctua-A14 FLX the best for the front of the case?
Just get NF-F12's for the front of the case and yeah get 140mm where you can.
https://linustechtips.com/topic/155038-case-fan-advice/#findComment-2069613
