Help needed with memory timing, frequency
Solved by RONOTHAN##,
What are the models of each of the sticks?
That said, the general process should be the same:
- Set the memory voltage to 1.35V (or whatever the XMP voltage is)
- Slowly walk up the memory frequency (try 2133, then 2400, 2666, etc.) until the system stops booting.
- Lower the memory speed until it starts passing memory stress tests.
- Start lowering the memory timings one by one until the system stops booting, then raise it till it starts passing stress tests.
You'll need to become pretty familiar with the clear CMOS button since a lot of what you're doing is going to be messing with settings until the system stops booting.
