How can i fix audio bug when connect controller to pc?
TC ReflexYT
I can have my controller connected and my headphones all at he same time all running well (my headphones are also connected by usb not aux) then since I don't have a good cable yet when I accidently touch my cable with my leg the cable gets hit up which makes it disconnect (I'm using a original ps4 controller) then when the cable gets put down again a static audio bug starts and the only temp fix i have for it is just to disconnect and re connect my headphones. Video below (Hopefully its good enough but I can provide more of anything).
