What am I doing wrong?
On 12/30/2023 at 2:40 PM, shinegull said:Its whatever nozzle came with the printer. I kept with the creality nozzles still though
Didn't know glow in the dark affected it so much, since I went through a couple kg of that first before removing to white filament
It's all PLA or PLA+ though.
Glow in the dark is heavily abrasive due to the additives they have to put in to glow.
Moisture does affect print quality. Depending on where you live, your relative humidity could be very high (equator and surrounding sun belts) however 30-50% humidity has not shown to be an issue for my openly stored PLA or ABS. That said, drying your filament might help some or many of these issues. There's a couple of ways you can do this, but the simplest one is using your printer and the box it came in.
