PSU Wattage Help Needed
Solved by daemonowner,
The CX600M is 80Plus Bronze, semi modular, with a 3 year warranty. It's a solid budget choice. The CX600M goes for $105 on PCCG and Mwave, and the CX500M is $89 on PCCG. I don't think your build will need 600W, so you could save by getting the 500W.
A good step up from the CXM series is the Seasonic G-Series if you're willing to spend a bit more for the better quality and efficiency. The 550W is $119 at Mwave and $129 at PCCG.
Those would be my recommendations. I'm not too familiar with Australian stores, so if you have a preferred retailer you could look around for these units and compare prices.
