Hey everyone! Got a bit of a dilemma here and need some advice. So, the RX 7800XT is looking like a steal, being $140 cheaper than the 6950XT where I live. I'm torn between the two, and I'd love to hear your thoughts. From what I've gathered, both cards are pretty similar in performance, though some folks say the 6950XT might have a slight 10% advantage in rasterization.
Now, I'm planning to get into recording and eventually dipping my toes into streaming. Just so you know, the rest of my rig includes a Ryzen 9 5900X (got it at a crazy 52% off deal), 32 gigs of 4000 MHz DDR4 RAM (currently chugging along at 3200 MHz because of my Gigabyte GA-AX370M-DS3H motherboard), and a Samsung 980 Pro.
Power draws not a problem for me, so no need to worry about that. Any advice or recommendations on which/what I should get? Thanks a bunch!
(PS: I will also be playing VR games on my quest 2 with it via airlink or virtual desktop)
(PSPS: The 6950xt is $660 OEM and the 7800xt is a $520 XFX Speedster QICK319 RX 7800XT. Also in USD pricing.)
https://linustechtips.com/topic/1548451-need-help-with-choosing-a-gpu/
7800XT nitro+ or a higher tier card like it, its about $30-40 more expensive but much better cooler and OC'd very well, will probably bring that 10% closer to 5%
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
Whilst 6950XT is the faster card, at a $120 extra premium I don't think it's worth it. Just save the difference and get single digit fps (5-10%) less.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
4K max settings gaming is the only place where I'd consider getting the 6950xt,
but in lower settings and resolutions, if you're getting 100fps vs 110fps for example, you're paying 150$ for 10fps,
maybe wait for deals if you can? (unless they're already discounted)
if you use high resolution display for VR, then getting the faster GPU would depend on if you really need all settings to be as high as possible (high detail gaming in VR is still ambitious even today though), and if you'll play more VR than regular screen games
current PC:
PC configs I used before:
What's your experience with yours if you don't mind me asking? Just wanting to get an idea of what people actually get out of theirs instead of some comparison youtube video
That's what I was thinking too. I will wait and see if anyone else replies to the thread. Hoping people reply who have experience with one or the other to see their views on the card.
Virtual Desktop has av1 support so it may be better for me to go for the 7800xt for said support. Don't know yet
perhaps look at reviews?
in this video perticularly the 7800XT sounds like a decent VR card
(in the video, the stuttering mentioned was an actual app issue and not GPU issue)
current PC:
Only demanding game ive really played on it has been cyberpunk and MCC so far, cyberpunk i changed from 1080p to 1440p HDR recently (maxed graphical settings) and almost no lowering of frames that was noticeable, playing between 100 and 130fps depending on intensity of whatever is happening
Halo reach MCC i had to frame limit as i was getting between 600-700fps on max+boosted MCC graphcis, even hitting some 800fps when looking at a wall or low density area like a small featureless room. Its been great so far, I've OCd it to 2.61GHz Core clock and 2.59GHz Mem clock. Still only running around 50-60C in game
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
