WiFi issues on Custom NZXT PC
Solved by Robchil,
19 minutes ago, BearBearBear said:How would I go about changing that?
in devicemanager you open your wifi device and it says connecting using: some device.. press configer there and under advanced you should find some settings saying something about 802.11be .. that's wifi 7.. 802.11ax is wifi 6 and 802.11ac is wifi 5.. depending on how old your router is and what it supports you can set it to not use 802.11be not to be used when trying to connect.. or make it use ax or ac..
