Gpu not recognised overnight, need help
Solved by DoctorNick,
1 minute ago, PoopKink said:did all this, still comes up with an unrecognised gpu. i might just get a clean install of windows and see if that fixes it
Yes or try this first, remove drivers for the unknown devices, remember to mark uninstall drivers:
After that shut down and reseat GPU and maybe clear CMOS while you're at it, by removing the battery for 5 min while PSU is off.
